Any convertible owners run into this
There is a TSB on it, attached. It has repair kit part numbers.
If it is just a broken cable and the door and damper assy are intact it may be possible to fashion a DIY fix. I think there is a forum thread on it. You might be able to find it in a search.
The following 2 users liked this post by WhiteXKR:
Bill400 (02-17-2022),
Scott in PA (02-19-2022)
To anyone else who has this issue, page 5 of 6 in the TSB posted above says the opening around the sliding flap should be 89mm. I could only get mine to 88 which appears ok, but anything less is bad. I think what happens is the bolt listed as number "3" on that page, loosens and the opening shrinks. And once the gap around the panel has been reduced, the sliding panel may not immediately slide in when tension on the cable is released as the top closes. When this happens the panel gets pushed off the tracks and the cable breaks the next time you open it (or worse). My track broke. I was able to glue the broken part (and reinforce the entire track) with JB Weld original glue. Make sure the panel slides back in immediately after tension on cable is removed. If not buy new components.You may want to consider adding a self tapping machine screw in the vicinity of the bolt (#3) that is adjustable - to prevent it from sliding back (especially if you have kids that sometimes sit back there).
The following 3 users liked this post by Steven07XK:
Exact same thing happened to me recently. If you open the top half way and prop it, it might give you more room to get your hand in there to see if you can get the flap out. The TSB might also help with how to get the track back on.
Finally, I just did a post on using fishing wire to fix the cable and get the flap moving. Here's the link: https://www.jaguarforums.com/forum/x...p-step-256121/
hope that helps and good luck!
Elhajj33 (02-18-2022)
When mine broke, I was able to pick up the piece of broken track (it had fallen below) and glue it back on with epoxy. First I used just enough to glue it along the break line, then after it dried I went back and put epoxy wherever I could that would reinforce the track without interfering with how how the panel travelled. I had to carefully sand the channel too because some glue got in there. You may want to tape off inner track so you do not have this problem. I think my track is now better than new.
If you can not find piece of you track that broke off - if you are handy - you may be able to put epoxy in the broken area and create a channel with dremel tools.
Or, you can search for a used replacement part online (I see them on ebay sometimes).
You will need to have panel out of car to do this, and remember to leave proper gap when you put it back together,
beasleee (11-13-2022)
GhostRider9000
06-02-2017 07:40 PM
