Any electrical experts here?
I installed a set of Adamesh LED tail lights on my 2007 XKR, I am not sure this is a factor in the problem I am experiencing, but I do not have the stock tail lights to swap back in to rule it out.
Problem: Occasionally when driving the car's dash board will display a "indicator/bulb failure" for the Entire Driver side of the car. (Driverside Headlight, fender/sidemarker, and taillight) all at the same time. The weird part is, I am 95% sure the lights are all still fully functional as I have got out to check or have seen them working in the reflection of other cars.
I keep the car on a CTEK charger so the battery should not be the issue, although the battery is a few years old.
Any ideas what might be causing this issue or a good way to find the route cause? possibly a bad ground?
The hard part is I swapped these lights out right after I bought the car, so I don't know if this was an issue before or after the LED light install.
I plan to go through the grounds and connections thoroughly here soon. Maybe swap the blade style connectors on the LED kit with solder.
Adamesh now carries my Remote Top Kit. If a customer ever has a question he always contacts me to assist.
Thanks,
Mike
Mike,
I believe that when Adamesh first introduced their LED tail light conversion kit they used resistors to compensate for the lower resistance of LEDs, but had problems with the "indicator/bulb failure" warning. The later version replaced those resistors with light bulbs to equalize the resistance and eliminate the warning.
After you've verified all the connections, if you still have the "indicator/bulb failure" warning you may want to check and make sure all the resistors or bulbs are OK and haven't burned out.
If everything checks out OK and you're still getting the warning, try reinstalling the lights following the instructions posted by georgekale - see the link to his .pdf instructions in his post #51 in this thread: https://www.jaguarforums.com/forum/x...s-36907/page3/
I haven't done the conversion, but thought about doing it a while ago. Still procrastinating.
Stuart
Stuart
Your "smart" flasher unit flashes twice as fast (or keys the warning text) to advise you that one of the bulbs is out...or you might not know it was out. LED units draw so much less current the flasher unit sees the lower current draw as one of the lights (incandescent) being out. The solution is to add the resistor circuit in parallel with the lamp circuit to raise the current draw (which seems counter productive since that's half the reason I switch to LEDs) or find a flasher unit that has a lower threshold.
Mike,
Stuart
Stuart
Your "smart" flasher unit flashes twice as fast (or keys the warning text) to advise you that one of the bulbs is out...or you might not know it was out. LED units draw so much less current the flasher unit sees the lower current draw as one of the lights (incandescent) being out. The solution is to add the resistor circuit in parallel with the lamp circuit to raise the current draw (which seems counter productive since that's half the reason I switch to LEDs) or find a flasher unit that has a lower threshold..
Thanks for both of your replies.
The resistors would be the cheapest. I'm not aware of an alternate flasher unit that works. I actually ran across this problem working on a motorcycle. Isn't technology wonderful?!
