Any idea what this is?
Found this assembly attached to the wiring harness at the front of the engine.
Can't identify in the manual, and doesn't seem to be plugged into anything except the wiring harness. Looks like it has a mounting bracket that will attach it to something, but was just hanging free down the left front of the engine.
Can you identify?
Thanks!
Can you identify?
Thanks!
Possible. Weird, huh? I didn't take it apart, since I didn't want to screw up a sensor (if it was). So I don't know if it has connectors in it.
Any more bids? Not a whit of documentation that i can find. Maybe it's a special trigger for bad guy stuff in the Bond movies. Or it has a button in it that makes it change into an Aston Martin when pressed.
Can't identify in the manual, and doesn't seem to be plugged into anything except the wiring harness. Looks like it has a mounting bracket that will attach it to 192.168.100.1 192.168.1.1 something, but was just hanging free down the left front of the engine.
Can you identify?
Thanks!
Can you identify?
Thanks!
So the wiring guide image led me FL055, which appears in the electrical guide to be a pedestrian protection accelerometer connector ... maybe.
It'd make sense that it's a leftover, since the PPS doesn't exist in the American version.
(I can stop obsessing now....)
stuckon914
01-06-2019 03:32 PM
