Aston vantage owners
I've noticed as of late there has been a fair bit mentioning of the Aston vantage V8 (ajv8 variety) .
Has anyone actually owned on this forum. I've always wanted one however I only own the one vehicle and use it as a daily
and yes I do infact make use of the rear seats that is for my kids .
George05 (12-07-2019)
The following 4 users liked this post by mosesbotbol:
George05 (12-07-2019),
Panthro (05-19-2022),
Queen and Country (12-07-2019),
steve_k_xk (12-08-2019)
mosesbotbol (12-08-2019)
DB11 and XK were not contemporaries. DB9 would be a more apt comp. DB11 came out after XK production ended and ushered in an updated design language.
carealtor (12-08-2019)
If you're looking at a Vanquish, I'd go for a DB9 GT instead over the DB11. DB9 GT is quite close to the Vanquish outside of the steel/fiberglass construction and retains the NA 6.0 V12 in its final iteration. Can get it with the same updated center console too. Probably the best buy for a later model Aston is DB9 GT. Vanquish is quite a deal too, but one hit in the car and it's totaled if there's real CF repairs needed.
I will have lots to consider in the next couple years.
Man, I don't know about that. Sure, it's a LOT cheaper and such, but then it's even older than my XKR. I don't really want to backtrack or even stay on par, I'd want to upgrade. Vanquishes are a tad older design and the tech is older than a DB11, but they are still quite pricey. DB11s are newer tech and still look good, but they aren't a Vanquish.
https://www.astonmartin-lotus.com/as...vanquish-coupe
'14 DB9 4k miles for 94K
https://www.astonmartin-lotus.com/as...in-db9-coupe-2
Either would be cool by me!
bottles of DRC to share with your other leisure class homies! An oil service on the 12 will set you back 1.5 - 2K, which would get you 2 or 3 standard-issue bottles of Screaming Eagle Cabernet. Life is good at the top!
Cee Jay (12-08-2019)
The following 2 users liked this post by steve_k_xk:
Queen and Country (12-08-2019)
Your spot on !! It's a 08
I don't own
but are having serious thoughts about the purchase of it the main issue holding me back is I only have the one vehicle which I do use to carry the kids around.
If I purchased the vantage I'd have to get another car as well like a cheap run around.
I don't own
DB9 is similar proportions to the xk for me I love the compact size of the vantage and more importantly a car that handles better then the xk as I find it quite noise heavily more GT then sports car if you will .
In regards to the 4.7 your absolutely correct I'm pretty sure I'd be wanting more hp almost immediately from the 4.3 .
