Audio drops for a second every 10/15 seconds
I have a problem with the sound of the radio or CD in my X150 2006.
The sound drops for about 1 second every 10 to 15 seconds.
I already replaced the battery with an AGM one and bought a CTEK loader.
So voltage shoulf be OK.
Somebady experienced same thing and found a solution?
I have not had this issue in my X150 but did have this issue in my E-Type.
Assuming all speakers cut out regardless of source, I am told, typically, this is one of two/three things. The amp going into bypass due to a short or there being a voltage drop to the amp. Third is a bad amp or headunit.
It it took a while to correct in my very simple E-Type but that electrical system is more frail.
Best!
Best!
