Audio Screen Issues
Check the car battery!
98% of the time it is Low Battery Voltage which causes electrical associated problems.
Your battery should have at least 12.6 volts AFTER it has sat unmolested overnight.
Try charging the snot out of it with an actual battery CHARGER and not a Maintainer or trickle for at least 12 hours if not overnight.
You could also have an auto shop or store do a quick Battery Check and Load Check for you for free.
The following 4 users liked this post by Cee Jay:
I put in a new battery and changed the fuses but no luck my touch screen still won’t work. I’m not sure whether to order a screen or the CD player…I’ve noticed some say it could be the CD player that is causing the problem. Note: my radio works, my hazards work but my screen won’t illuminate. I can see the imprint of the screen display and the on off switch works but the screen remains dark.
Hi All,
These screens seem to be failing on a regular basis. Jaguar charge (if they have stock) over £1,000 to supply. Despite rumours, the unit is the same as fitted to the XF (very slight difference to metal frame around LCD screen, which isn't a problem). Just make sure that if you try an XF one, secondhand, it is of the same age. I bought one on Ebay for £20 and it worked perfectly. Good luck
assuming you tested the new unit and it works, yes swap the mounting brackets. Check every function.
needanswers
08-28-2023 09:12 AM
coleman645
09-02-2018 10:29 AM
