Audio streaming
In my 2009 XKR I have plugged in a mini USB into the inside port of the center console. Has about 500 to 800 songs downloaded from my computer.
Using the mini USB in the port provides no wire hookups, no other connections, just plug and play after "docking the device" from the Nav Screen under Audio>Portable Device>Dock Device>Folders
Sound is spectacular with the B&W system. Its like having a JukeBox in the Jag.
There have been a few threads on the topic.
(searching for this is why I joined up!)
As far as I can tell, no-one has found a blue tooth device design that streams to a non Apple device. Logically, you'd have thought it was easy, but not so.
Much kudos to whoever figures it out!
iSimple ISFM21 TranzIt Universal Bluetooth Enabled FM Transmitter Car Kit for Android Devices, Blue
This is the best solution I have seen to date (for the money) for non-apple devices. Unfortunately it is not a "true" bluetooth direct stream to the car's audio system. You wire up this device inline with the antenna port on the back of the nav system. This then allows you to stream music via bluetooth to this module, which then is wired to the radio. Quality likely is poorer than a direct stream, but I would imagine it is not too bad. I am curious if anyone here has used this product.
Amazon.com : iSimple ISFM21 TranzIt Universal Bluetooth Enabled FM Transmitter Car Kit for Android Devices, Blue : Car Electronics
