Auto Boot Up Cell Phone
This was posted under the General Forums but realized it probably this group that might respond best to the lack of gauges issue.
I'm hoping someone here knows of a USB power port that acts like a USB cell phone wall charger, ie auto cycles the phone power when charging? That would allow the phone to automatically start when the ignition is on.
I've installed a bluetooth OBDlink-LX in my 12 XK that powers on/off with the ignition thus won't drain the battery. Additionally, I've rooted an unused Droid Razr Maxx with an app that auto launches the Torque app and one that shuts the phone down when the ignition is turned off. All fits well in the car and works fine and could be permanently mounted except that the phone has to be powered on maunually.
There are a million different types of car plugs out there but I've seen none that gives detail on how they might power a cell phone like a wall charger does. If anyone knows of a smart USB port plug like that I'd be greatful to hear of it.
This is just a power on feature. I'm not sure I'm tracking your ask. I wired this to the glovebox lighter wiring (behind the glove box), it sends 5 volts to the USB port. I would imagine from that you would use a USB A to USB mini or micro cable, but is reads like you've already done that:
Your issue is that you need the phone to turn on when power is fed to it. That has to be solved by programming the phone. I presume you want something like this:
pwpacp (04-27-2018)
I think with phones >2014, they have a built in scheduler so you can schedule the phone to turn off. But unless you're a creature of habit, yes you'd have to shut it down yourself on some occasions. The sleep feature would also minimize phone battery drain while waiting for the scheduler to shut the phone down.
pwpacp (04-27-2018)
I also wonder, why are you using another, dedicated phone for that? I too have an OBD2 reader wired so it is only powered when the car is, and as the phone detects it, Tasker fires up Torque. I have my phone on a small round magnetic phone holder on the vent. I know the that's not the prettiest location for a phone, but then it's a very convenient one, especially as I also use the phone as a navigator.
pwpacp (04-27-2018)
@Sean W, Cee Jay, and Aonsaithya: Thanks for your replys.
I'm using the cigar lighter outlet in the ashtray which is a switched receptical. Since it is an old unused phone I wanted to leave it leaning in place (landscape) over the ashtray and had hoped to make a bezel to keep it permanently in position there for a finished look. That is where it sits now connected with an extremely short USB cable that tucks away neatly. Other than being required to turn the phone on manually it all works fully automatic. That is after the car starts & phone is turned on it connects to the OBDII and launches the Torque app. When the ignition is turned off I have an app that shuts the phone down....I had to root the device for that to work.
I have tested the phone using a USB wall charger that automatically boots the phone on when it is plugged into power. That is the feature I'm trying to replicate with an automotive USB plug but have been unable to ID anything on the market that can emulate a USB wall charger.
I know it may be possible to modify the phone's system program to sense when power is applied to it's micro USB port but I'm not geek enough to try that.
I found some instructions on the web for it but they don't include script or detail usable for my Motorola Razr Maxx. And then again, I truely lack the confidence to take that on. Hence, my call for help hoping someone may have already solved this puzzle.
Cee Jay (04-27-2018)
Received 2,012 Likes
What is the brand and model number of that charger?
Worst case, get an inverter that is powered by the lighter plug, and have it drive the USB charger.
It's a Motorola wall charger but have been able to substitute another brand that did the same. I tried an inverter with the charger and it worked like a charm, but have to admit I was hoping there might be something integrated into a car charge port that would do the same thing. Worst case, I suppose, I might be able to dissassemble the inverter combine everything into a box and hard wire it under the instrument panel but that is extreme.
Your welcome. Hope it works. Tasker requires a bit of patience to learn imo. It can do a lot but it isn't always easy. Think learning excel:-) So you can set it up to start the phone, launch Torque, change brightness given the time of day, shut down, etc.. but you already have everything else set up so the step by step should fit well. Let us know how you get on.
So Tasker can't power the phone on from an off state then plugged into an in-car charger. It would seem the only way to accomplish that task will be to modify the system code to make it think it is connected to a computer port. I'm thinking I might pick up a used Samsung phone sometime later to attempt a system code modification. There are a few DIY instructions on the web that appear to work for what I want.
My thanks to everyone for contributing on this for me. Though for now, I'll just have to tolerate the labor of pushing the power button......I know George Jetson would sympathize.
What about simply leaving the phone on? Set up Tasker to switch on low power mode & airplane mode so it turns off all the radios and such when charging stops, and then turn on everything necessary when power starts flowing again? It ought to survive several days like that. I reckon you'd also get a much faster startup vs. booting up every time.
Jaguarjc
28
07-26-2018 05:58 PM
09-28-2006 01:33 PM
