Auxiliary junction box
I have a friend with a 2008 xk8 convertible. Car will start after some effort, run for a couple of seconds then shut down. Took it to mechanic who advised that the auxiliary junction box in the trunk is faulty and needs replacement. Part no. C2p9445 or 20669. This part is impossible to find and is listed on most sites as discontinued. I have a few questions. Does the problem sound like a junction box issue? If so, does anyone know where one can be found or is it possible to repair or rebuild the existing unit? Any other suggestions as to what the problem could be if not the junction box. We have not used a code reader to confirm the problem but thus far are relying on the mechanics opinion. The car is in beautiful condition and is of no use unless he can resolve this problem. Thanks in advance for any help you can provide.
Don B (04-20-2023)
There are no 2008 xk8s.
Disconnect the battery earth. Remove and clean the large terminals to the box . there have been examples of bad connections between the eyelet and the cable. Check if the connections get hot when cranking. (use your finger). If the box is cracked you just discovered what epoxy is for.
It could be many things certainly but I would first check all major ground points to the body of the car. The ground posts (any and all of them), can corrode so best to remove the cables from said posts, clean and replace. In other words, don't just look at them and give them a wiggle:-) I've experienced your symptoms in the past, though on a different car. It was a loose ground strap on the body. Doesn't cost anything to check except your time.
A little more history or background would be helpful.
sws805
12-14-2012 09:36 PM
