Back into Jag Ownership!
Bottom line ‘drivers’ need the poly bushings!
Signs of waterpump failure are predominantly loss of fluid and pink stains on the underside of the car from the coolant burning off.
I had mine serviced last week and indy advised mine was absolutely fine atm.
In Polybushes I had them fitted all around on my x100 with new shocks and 2005 lowered springs back in 2009. People (On the forum) advised that the ride would be intolerable...it wasn't and transformed the car. However that was on 18" alloys so there was increased comfort to start.
The positives were didn't have a busy fail again and it transformed cornering The 150 is far sharper to start with, so will be interested in hearing your views
Thoughts on the thermostat housing issue, is that applicable to the 4.2 SC motor?
Received 2,048 Likes
There can be a severe rattle coming from the water pump almost sounding like the supercharger is failing. That was the signal from mine that prompted replacement as we were looking for the source of the rattling sound. I put powerflex poly bushings on my X100, and there most certainly is a "moaning" noise that can be quite annoying that comes with doing so.
#28
As far as noise from poly bushings I have done at least 10 cars of varying types and never had an issue. 5 of my cars currrently have all poly bushings. I have about 2500 miles on the XKR since the job was completed. Driven in heat, humidity and rain and no wierd suspension sounds whatsoever, nothing. I can’t speak to your X100 but my X150 has responded to poly bushings wonderfully. They have certainly made the car a better drivers car with no apparent trade off.
I can think of no reason why a properly installed poly bush would create a moaning sound. Strange.
My car has a very light rattle/ticking noise at idle, will look into the pump.
#30
From my experience they usually squeak and not moan. This usually starts after the grease in the bushings get washed away. From a handling aspect poly is firmer and gives you more of a road feel. Could be the exhaust note is covering it. I made a sacrifice buying the R vs the XK regarding ride quality but the ride is acceptable by compensating with a softer tire compound.
I only grease the inner openings of the bushing into which the metal sleeve slides. The bushings have grooves in there to retain grease, I always fill in there real well and then slide the metal sleeve thru. I never grease the outer portion of the bushing that will be in contact with the control arm, always press them in dry.
I believe the bushing should rotate on the metal sleeve and not rotate in the control arm. I know people make the mistake of greasing the outer portion of the bushing before pressing it into the control arm and end up with noise issues. I believe that mistake is the source of most of the noise issues as that large surface is not supposed to rotate in the control arm and it is much easier to wash grease away and have it get dirty in that location. Just hypothesizing here but I have never had squeaky poly bushings on any of my cars.
The XKR is amazing to drive since the suspension refurbish, it was ok before but truly great now.
The following 2 users liked this post by 09XFSuper:
mosesbotbol (12-04-2018),
Panthro (02-10-2019)
Anxious Jim
11-11-2012 10:27 AM
txbrit
08-08-2012 06:17 PM
arlingtonman
07-11-2012 03:27 PM
jagxkrtoofast
12-22-2011 02:42 AM
