Bad drone/resonance
Old 08-24-2017, 06:09 AM
peterv8's Avatar
Default Bad drone/resonance
This exhaust came on the car and I have no OEM exhaust to switch with.
I have a loud drone at around 1500rpm, is there anything I can do cheaply or is
it best to buy another exhaust? I love the sound of it outside but it is getting a bit to loud for me in the car too.
Old 08-24-2017, 06:13 AM
steve_k_xk's Avatar
Received 1,550 Likes on 895 Posts
Larini do a brilliant sounding rear box or a cheaper option would to simply get the xkr quad rear box from eBay
Old 08-24-2017, 07:12 AM
kj07xk's Avatar
Received 1,997 Likes on 1,335 Posts
If you have access to that lift, it shouldn't be to hard to isolate where the drone comes from with someone holding the engine at 1500 rpm. Find what's vibrating or if it's internal to that exhaust.
Jag had its own drone issue on early models and made a set of clamps that went on the cats and bolted to the transmission housing.
Old 08-24-2017, 07:21 AM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
Even with OEM exhaust there was a narrow RPM range drone on the XK. Jaguar design related. There is a Jaguar procedure to fix it, but it's quite involved. Whether your exhaust compounds it or not I don't know.
Old 08-24-2017, 07:35 AM
peterv8's Avatar
It's on my scissorlift in the picture!:-D
How do I find the drone, feeling on the pipes for vibrations with engine running at 1500rpm?
Do you have a link for he procedure?
Old 08-24-2017, 07:39 AM
peterv8's Avatar
Am looking for an OEM XK or XKR box but shipping to Sweden is often very expensive but will keep looking!
Old 08-24-2017, 07:59 AM
Ranchero50's Avatar
If you have the skill and time, experiment with different mufflers. I played with mine to minimize most of the drone but I have issues around 2100 rpm. My build thread spent a good bit of time on the muffler trying to tune the sound.
Hoping to pick up a stock XKR box tomorrow for comparisons sake.
Old 08-24-2017, 09:36 AM
Rey's Avatar
Rey
Rey is offline
Drone is an issue with almost all aftermarket exhausts, except Corsa. Mfgs like GM and Jaguar deal with drone through an "active exhaust".
Suggest research into Helmholtz resonators. A U.S. company, Synapse Engineering, is now selling Helmholtz exhaust resonators. See: https://www.carid.com/synapse-engine...285628807.html
Old 08-24-2017, 09:46 AM
Jag's solution included additional hangers and clamps to mitigate the drone.
Old 08-24-2017, 10:29 AM
michaelodonnell123's Avatar
I have driven both the xk8 and xk models and have never heard of any drone with the stock Jaguar exhaust. My advice would be to bring it back to stock.
Old 08-24-2017, 11:02 AM
peterv8's Avatar
Found this exhaust for a good price!:-
The silencer is alot bigger so it should be more quiet or....?
Old 08-24-2017, 11:20 AM
Ranchero50's Avatar
Find reviews that make sense and maybe so video of it cruising. Real PITA to get good info with a low production car like ours.
Old 08-24-2017, 12:25 PM
Rey's Avatar
Rey
Rey is offline
Don't bother with a no-name aftermarket "look-a-like oem" exhaust. It will likely drone.
Perhaps the best alternative is a used OEM exhaust. Ebay USA has this XK version for $500:
09 Jaguar XK Exhaust Muffler Silencer 6W83 5K244
If you want the XKR version expect to pay a lot more. The XK and XKR are both "active" exhaust. The XK version has a spring-loaded valve, and the XKR version has an electrically-operated valve.
Old 08-24-2017, 12:49 PM
The drone comes from before the muffler section.
Old 08-24-2017, 01:31 PM
Queen and Country's Avatar
Received 2,383 Likes on 1,609 Posts
There is no substitute for an OEM exhaust!
Old 08-24-2017, 03:40 PM
sov211's Avatar
Received 2,248 Likes on 1,361 Posts
Correct. The constant attempts to "improve" aspects of these cars is an attempt to second-guess engineers who know intimately the cascade effects of changes (the substitution of poly suspension bushings is a perfect example). Jaguars are engineered for refinement consistent with performance and longevity. Fiddle with things and you lose something to possibly (and the adverb is important) gain something.
That said, it should be noted that the early cars had a resonance problem in the lower rpm range - very annoying. Jaguar solved this with a bracket kit (which an earlier respondent mentioned) that stabilizes the catalytic converters (I think) to the transmission case. It works brilliantly, entirely eliminating the resonance. I had this done on my 07 years ago. Instant relief!
davchr (09-27-2017)
Old 08-25-2017, 12:47 AM
peterv8's Avatar
Thanks guys!:-)
I have found an OEM muffler for a good price!:-)
When it arrives I will mount it and hopefully the drone is gone. Could be I need the bracket kit as my car is an early one.
When I have a quiet car with the OEM muffler I will try your suggestions and see if I can get the drone to be a little less with my loud muffler.:-)
Old 08-25-2017, 10:37 AM
peterv8's Avatar
Mine is a 2006 so I would like those brackets!
I might have them so how do they look and where are they mounted?
Is there a part number?
Old 08-25-2017, 12:01 PM
I believe there's some welded supports to underneath the body. I would look underneath for supports that were added after. Most likely you did not have this TSB done as it seems Jaguar wasn't promoting the fix unless you complained.
Old 08-25-2017, 04:41 PM
kj07xk's Avatar
See this thread:
https://www.jaguarforums.com/forum/x...ne-pics-87514/
Part numbers are:
C2P13477 and C2P13478
