Ball joint boots
Odd, as far as I can see, those boots aren't a separate part. They're labelled as just part of the ball joint. That would imply that you could only replace them by replacing the entire ball joint. If that's the case, you're effectively replacing something in order to protect it so it doesn't need replacing. May as well just pack the boots with grease and keep an eye on the joints; when they develop play, replace them.
Of course, it's possible that you can't replace the ball joint and you'll need an entire new arm.
Lothar52 (08-24-2014)
Finbarr1975
09-16-2023 02:52 PM
Camnelson324
09-27-2015 08:48 AM
Woznaldo
09-26-2015 11:02 AM
