Ball joint rubber boots
Hi Sean
I see you you replaced yours a year ago
here is updated link you mentioned
https://www.ebay.com/itm/2x-Polyboot...EAAOSw9mFWJ9~u
These are not the same shape and material as originals.
Can you please share your experience installing them and how they last sine installed?
thanks
thanks
Others options on ebay
https://www.ebay.com/itm/Jaguar-XK-R...72.m2749.l2649
https://www.ebay.com/itm/2x-Polyboot...72.m2749.l2649
not sure what will best fit...
Not these, there are reports of these things failing MOT, getting replaced and failing two years later. They are not honest rubber like in the OP's image, more of an opaque silicone rubber that seems to dry rot really quickly. The joints underneath are some flavor of teflon and wear really well. I don't understand why Jaguar chose that material.
Ranchero50 (11-12-2018)
Do these use silicon grease?
I'm replacing both front upper control arm ball joint boots on MY2011 XKR. Car has only 24K miles so just replacing the boots and repacking w/ grease.
My question now are the joints lubed with a silicon grease? Sure feels like it.
I measured the ball joint stem at 12 mm and the upper seat diameter at 30.4 mm. (I ordered two different pairs: 12-29-24 and 13-30-22. I let you know which fit better. )
Using "polyboots" generic items off eBay. >> https://www.ebay.com/itm/2x-Polyboot...53.m1438.l2649
