Battery acid in the trunk.
Old 05-24-2014, 03:13 PM
scm's Avatar
scm
scm is offline
Received 1,482 Likes on 1,122 Posts
My engine bay is so full there isn't room for a battery in there as well!
Old 05-25-2014, 07:56 AM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
I think the battery migrated rearward in Jags when they started fitting V12s and needed the under-bonnet space (not sure about the V12 E-Type). Having made that design decision, there was no point in doing it differently for the 6-cylinder models. I assume they carried it on into the later Jags because the battery got a lot bigger. There may also be a benefit in keeping it away from the under-bonnet heat.
Old 05-25-2014, 08:35 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
My XJS had a rear trunk mounted battery.
Old 05-25-2014, 09:52 AM
axr6's Avatar
It does not hurt the weight distribution, as well. The stock battery is something like 58 lbs and with the Eco, second battery, it must be pushing 100 lbs total. In a front-engined car it usually pays to move the heavy battery to the back. The only thing that the XKR should have done better is to move the battery down low, to the bottom of the trunk, (as the XF and XJ), for lower center of gravity.
jluckcuck
11-06-2015 07:49 AM
Swagguar
09-30-2015 01:34 PM
oldjaglover
09-29-2015 03:27 PM
Markus
09-28-2015 01:55 PM
Quick Reply: Battery acid in the trunk.
