Battery charging / CTEK advice please
Is anyone suggesting that it does have bms?
In my situation I killed the battery and simply put my trusty 40 amp charger on the battery, while still connected to the car's electrical system. Next thing I knew I had blown out the alternator.
Somewhere there is a Jag warning about doing that to 2007-2009., but it seems reasonable that a smaller charge would be less likely to cause damage.
EDIT: Sorry, I thought you had said something about being told BMS + CTEK was the issue on your car, think it was the next post which referenced the 2009 having BMS which it does not.
gmsclassics
01-27-2018 11:20 AM
