Battery drain values
Tried to start car - centre console display said "take wallet to Jag dealer"..![Icon Handball](https://www.jaguarforums.com/forum/images/smilies/icon_handball.gif)
Battery at 10 volts..(bat is 7 years old) - the car had been stood for a week.
Charged batt - disconnected bat and placed an ammeter in series with pos lead.
Current readings after turning ignition off was around 6 amps - reducing to 20 milliamps after 5-6 minutes.
Probably time for a new battery.
The reading of 10v is all you need to know, even a charger or maintainer can't save it. Sears or most auto store will install for free and save you a bunch over the dealership unless you're under warranty. It shouldn't take more than @10-15 mins to do as you probably know if you tested out at the posts
I'm just going to order a batt from Jag and install it myself. I was looking buying one of those Absorbed Glass Mat batts though discussed on the forum.
Not sure which way to go.
Good news is i'm no longer getting "check tire pressure" cycling through all four tires now after the "reboot".
I guess Bill Gates wrote some of the software...
Walmart has the correct battery sourced from Johnson Controls, and
it has the correct venting. Just make sure that the venting is still in
the attached plastic baggie. Costco does not carry the correct size.
It is the same as the original battery. Varta is owned by JC now.
7 years was a pretty good run. You can expect the same from
the replacement. No need for AGM.
britannia (08-02-2016)
