Battery Issues with 2013 XK
#41
A person could retort with TLC........ Trump Lies Constantly. Not a phrase, sentence nor sentence fragment escapes the mouth of Trump without at least 75% falsehood. Trump thinks, "if I say it, that makes it true". It really doesn't.
#42
Of course; and I sincerely apologize for offending you and anyone else. I intended no hatred, and was just poking fun because my twisted sense of humor saw that I could use all of u102768's words that way.
P.S. If you can't make fun of yourself, you have no right to make fun of others
#43
#44
It's all good, Stewart, I just didn't want politics to take over the thread.
Back to batteries!
My F150 battery system sucks. Be glad ours aren't as bad. I drive that quite a bit more than the Jag, and the battery in it keeps getting lower and lower every trip. I have a second CTEK for that, and also a Battery Disconnecter that disconnects the positive lead when battery voltage gets below 12.3 volts or somewhere near that. It retains enough power to start, anyway. It's saved my butts on numerous occasions.
Back to batteries!
#45
Does it still monitor when the car has entered the Deep Sleep? BMW also uses a smart monitor system, I find it annoying as the batteries in these cars (BMW included) don't last very long in most instances and require external assistance. Doesn't seem all that smart to me!!!
#46
Funny, isn’t it? BMS is supposed to make extra long lasting extra expensive AGM batteries last even longer what the manufacturer states yet my 2015 is on battery #4 AND BMS module number 2 not working including multiple ECO battery replacements. Keeping it Jaguar, the SuperV8 and 2008 XKR had original non-AGM batteries that lasted 6+ years without CTEK and without BMS. Maybe a class action is in order for misrepresentation....
#47
#48
#49
Just that stupid injector and the STUPID DANG MORONIC IDIOTIC LAME CRAPPY T-P-M-S light.
Of course NOW you probably made me JINX myself.
Thanks for that.
#50
NOTE: When using a Jaguar-approved battery charger
or maintainer, connect the charger to the recommended
ground point to ensure that the charge flows through the
BMS module instead of the negative battery terminal.
Failure to observe this will log a diagnostic trouble code
(DTC), and incorrect battery condition information will
be retained by the BMS module due to unmonitored cur-
rent flow into the battery. However, the system will rec-
ognize and compensate for the change in the battery
status after a period of time.
ralphwg (11-10-2020)
#51
I have been very pleased with this car, just 2 batteries in 4 years. I don't give it the full Prius treatment every night, just plug it up to the maintainer every week or two.
42,000 miles and original water pump (knock on wood for sure), only repairs have been compressor while under warranty and a lower coolant hose replacement out of warranty.
I look at the battery as an expendable part, cost me all of $130 and 30 minutes.
