Battery replacement
Good afternoon....Wanting to replace my current battery with a "non acid" one...so far have had no luck with my mechanic finding one via the parts houses...
was wondering if someone had replaced the battery on a 2008 XK convertible and if so what brand and part number if possible....thanks..I thought I read something here
about this being done but haven't located it yet....
Stuart S (08-12-2018)
Well not true but perhaps not relevant for the OP. AGM batteries were installed in Jaguars, but on the 2010 >. He has an 08. So the question relates to the alternator and it's charging rate. The battery monitoring system would provide self calibration and adjust the charge on the 2010 >, but no such animal on the 08.
Sean W (08-04-2018)
I think the whole AGM batteries actually overcharging is a bit overblown, but no data to support it, just no horror stories that say otherwise. I suspect if you do an excessive amount of highway driving, it could shorten the battery life due to overcharge. For most of us on the forum, I doubt that's real life.
Sean W (08-04-2018)
https://www.tayna.co.uk/car-batteries/bosch/s4013/
GGG (08-05-2018)
I mentioned it in the past that talking to my service manager he said he never saw an AGM battery in any XK/XKR delivered from the factory. He did mention that he first started seeing AGM batteries when the start/stop feature was available in the Jaguar/LR vehicles. But he mention the AGM was a 2nd battery used in the circuit to supplement the start/stop feature. It is hard to tell what had been installed in any X150 unless you were the original owner or had the battery history of the car. So I suspect there is no real data to support either argument. The statement in the page above is broad to cover all vehicles and the not also states replace wet with wet and AGM with AGM. The real question is does the charging system need to be adjusted to either battery and if not what will happen. As a side note why does the Ctek have a specific charging rate for AGM vs flood.
Sean W (08-05-2018)
Thanks for all the info....if I am reading this correctly it appears that its not recommended..however there hasn't been any problems with doing so...
I just want to eliminate all the gremlins that a cheap battery brings with it...which is what my dealer installed when I bought it 3 years ago...thanks again
Dan, yes. If it were my car and I didn't do extensive highway driving @ freeway speeds, I would be comfortable with an AGM.
snkpkp
01-14-2021 09:52 AM
BigCat09
12-04-2019 03:06 PM
cat_as_trophy
01-26-2014 07:40 PM
Mark Scotton
24
01-23-2013 09:27 PM
Mccalist
12-14-2009 09:05 AM
