Battery terminals for CTEK
Old 02-15-2020, 03:28 PM
whedonum's Avatar
Was a tad impatient and pulled the battery out since the handbook said the reset procedure is relatively simple.
This video helped to learn how to remove the battery if anyone's interested:
Old 05-28-2020, 01:38 PM
Marc Voorhees's Avatar
Posting here for posterity. This is how I set it up in my 2011 XK
Bought
Ctek MUS 4.3
Ctek comfort indicator panel
Ctek comfort connect (8ft)
Took all of 15 minutes easy to cut through the trunk liked for the panel and seems very stable
Passenger side (us) in the spare wheel well
On the side of the roof hydraulic pump, TONS of space back there
Had to lift out the liner a bit to get it to fit under the carpet, but I got it back there
Attached to the positive side of the battery
The following 2 users liked this post by Marc Voorhees:
guy (05-28-2020), ralphwg (05-28-2020)
Old 05-28-2020, 07:36 PM
Stuart S's Avatar
Received 6,320 Likes on 3,465 Posts
Marc,
What model year is your X150 and is it an //R? That information is not in your Public Profile and you don't have a signature block. It matters as to how you can attach the CTEK ground lead and other things. You may want to add a signature.
Stuart
Old 05-28-2020, 07:46 PM
Stuart I added the car to the original post, I THINK I have now created a signature. 2011 xk, everything welt together very easy and per other suggestions, I did not ground directly to the battery.
Stuart S (05-28-2020)
Lothar52
12-10-2022 03:10 PM
bjmawg
08-26-2021 07:59 AM
gmsclassics
01-27-2018 11:20 AM
ek993
01-07-2018 07:19 PM
06-XJR
16
07-05-2016 11:13 AM
Quick Reply: Battery terminals for CTEK
