Battery Trickle Charge Question
Given all the suggestions to get a Ctek 4.3 to ensure the battery is topped up, I've looked into options to make that work in my current living situation where I don't have a garage or outside power source. The current alpha version of "the plan" is to attach the Ctek to something like a Goal Zero Yeti 400 (Goal Zero Yeti 400 Lithium Portable Power Station | | Goal Zero) and attach either a 50 or 100 watt Boulder solar array to ensure the Yeti's battery is always at 100%. The solar panel size will be based on how much draw the Ctek puts on the battery...if a 50 watt will keep it topped off while trickle charging the XKR's battery, then that's the solution, otherwise, the 100 will do the job.
The solar panels will be located on the cargo cover so that they have unrestricted access to the sun and the Yeti will be under the cargo cover in the trunk.
Does this sound feasible or am I making much ado about nothing if this is a daily or mostly daily driver?
If it is being driven daily for more than short runs there shouldn't be a problem keeping the battery healthy. As stated in many discussions on the forum, extended periods of non-driving or successive short operations that are taxing to the battery's charge level. I only use my tender when not driving more than 3 to 4 days at a time or when I've been out and about on short trips around town for a couple days straight.
