Beep when locking car quit working
On Double-Lock? A single press of the fob lock button locks the doors, and a second press sounds the beep. Same with the buttons on the exterior door handles. The second press (Double-Lock) isn't really a thing in the US marketed cars, but in other markets the double lock makes the doors unopenable from the INSIDE.
Regardless, have you tried pressing the button two-three-four times in a row? Does a single press lock the doors? Does the boot opener button open the boot?
You may have a bad Fob Battery.
Need More Information!!!
Alarm sounder is at fault as per IanXF's post. I had the same thing, seems fairly common. On the UK cars it's on the right (driver's) side of the engine bay underneath the bonnet airbag behind the coolant header tank. The airbag has to come out to replace so disconnect the battery and wait twenty minutes or so before messing with that. Access to the bolts etc. is a pig so flexi socket extensions will help a lot.
Well, my light s flash but I can't discern a beep. My wife might be able to hear it though. I'm deaf, the VA said so!
Cee Jay (09-15-2018)
Received 2,012 Likes
Jon89
01-08-2015 01:06 PM
