Big a
Old 09-25-2011, 03:25 PM
Big A's Avatar
Default Big a
My jag xk 4.2 2007 is to quiet - can i remove the 2 blocked ports on the rear silencer and have quad pipes out the rear as per xkr - help
Old 09-25-2011, 03:52 PM
davewhitt's Avatar
as i understand the xk and xkr have two different set-ups .the xk has a tim valve but the xkr has a active valve which needs a vacuum pump to close it ,so if you put a xkr rear box on a xk the valves would be open all the time aka more noise
Old 09-28-2011, 03:29 PM
Big A's Avatar
Default Big a
Thanks for reply but can i remove the tim valves on my existing xk
silencer and add the two pipes to give me a quad outlet look like the xkr will it be to noisy - regards
robbing
03-05-2024 10:51 AM
TreVoRTasmin
02-23-2021 03:13 PM
Finbarr1975
10-04-2015 05:32 PM
280zx-turbo
10-02-2015 02:52 AM
JagBrian
10-01-2015 12:52 AM
Quick Reply: Big a
