Bilstein shocks
Dunno who makes 'em, but there isn't a 'sports suspension' option, just the standard variable shocks. There is the 'Dynamic Pack' which includes a lowered suspension with different front uprights, but I believe the shocks are the same, just running different Active Dynamic software. Maybe someone fitted an aftermarket system.
Williamhenry (05-05-2014)
Theoretically, yes, you could fit the parts - but I suspect you might have trouble getting hold of them. Also, I know that the Dynamic Pack has a different software build and/or suspension maps to the standard XKR, and I have not been able to find anyone who can do a custom software load into the Active Damping Control Module. I've been looking into it because, although my 75 has the same hardware as the Dynamic Pack and the XKR-S, the software is an earlier version. But I can't find anyone who can load the R-S software into my ADCM.
Ngarara, thank you so much for your reply. I can tell from your number of posts that you are right about the tire pressures 36 front and 33 rear..........all my life I've been told the opposite....to always have lower pressure in front for softer ride. Share with me the reason for higher pressure in front. I would like to know.
Thanks again for your help
To be honest, I don't know why - that's what is written on the sticker on the door (I double-checked before I posted). I'm guessing that there's a lot more weight over the front. Also, my fronts are 255/35 whereas the rears are 295/30; perhaps the difference in profiles and overall volume makes a difference.
Williamhenry (05-06-2014)
I have always set the rears to a higher pressure as well.
I guess you should go with what is on the car. Although they differ, the workshop manual and specification guide both have it the more normal way round for XK's and XKR's.
The specification guide has both at 36 for the Speed Pack cars.
Ngarara (05-08-2014)
Ok, that's just feckin' barmy - either I'm going blind/bonkers (always a possibility), or the spec is backwards on my door label. I checked it recently before doing tyre checks and then looked again last night before I posted, just to be sure. I'm going to take yet another look at the label, and get a photo this time.
Once I have the evidence, if things don't match, I'm going to pester Jag.
Is that a different list that the one that you posted above? That shows 33 front, 36 rear.
Yeah, I wondered about that. We'll see what the cat people say...
Yours may be like it is because the rear tyres are 295's whereas all the other documentation only goes up to 285's.
That bit from the workshop manual shows 30/33, same as my car.
