Black trim
Old 12-12-2021, 07:12 AM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
Default https://www.ebay.com/itm/265166877990?hash=item3dbd2d7526:g:n2AAAOSwnzJgpo3 q
Currently available if the op is still interested in the performance seats.
These will bolt straight in only requiring a seat calibration on SDD
jahummer (12-12-2021)
Old 12-12-2021, 10:06 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
Prices like those above are why it's more profitable to take an XK apart rather than put one back together.
Old 12-13-2021, 09:44 AM
gkubrak's Avatar
Here is my trim. Not too bad. Next time I will get the gloss one to match the mirror trim that I painted. Now there is nothing silver on the car at all. Also, when I peeled off a portion, it DID take off the paint from the trim.
The following 3 users liked this post by gkubrak:
Cee Jay (12-13-2021), DGL (12-13-2021), Sean W (12-13-2021)
Old 12-13-2021, 10:32 AM
Sean W's Avatar
Received 4,256 Likes on 2,379 Posts
was it a DIY @gkubrak ? I'm assuming it's vinyl and not paint as you mention you peeled a piece. Was the trim removed or done in situ? How wide and log was the vinyl? How did you get it down below the A pillar? Was there enough room just opening the door? Any other tips and tricks?
It looks great.
Old 12-13-2021, 12:40 PM
gkubrak's Avatar
It looks great.
Yes DIY. Yes vinyl. In-situ. Measure the trim to get an approx length, I forget how long it was but make sure you have some extra also incase you scrap a piece. Same with width, get something an inch wide at the minimum. Opening the door helps and you can get a finger/plastic tool in there as well.
Other suggestions:
- wipe the trim with alcohol prior to application (very important otherwise it will peel off easily)
- get yourself a plastic trim tool/application squeegee
- don't try 1 piece all the way around the rear window, just use 2 separate strips and cut them in a single, overlapping common point
- use your fingers to smooth out the vinyl, then use the trim tool to 'tuck' the vinyl into the edges, then use a razor to cut off the excess
- use a heat gun or hairdryer for the corners
- cut the strip into (3) predetermined lengths, then peel the backing little by little as you progress over the work area
The following 2 users liked this post by gkubrak:
Old 12-13-2021, 07:52 PM
v8moise's Avatar
I used to own a shop so we painted the trim gloss black. IMO gloss black matches the rest of the car and the windows. It was about 5 years ago now and still looks great. If I had to redo it now (not having my shop) I'd wrap it, its easier to DYI and you can take it off whenever you like.
v8moise's Avatar
Originally Posted by DGL
I learned something I never knew. The black door and window trim was only offered on coupes with the black pack and not on convertibles with the black pack. All convertibles with the black pack or variation of it never came with the door and window trim in black.
Also, can anyone tell me the name of these rims??
  #28
Old 12-13-2021, 08:28 PM
Cee Jay's Avatar
VORTEX, but these ones are painted instead of having the shiny bits.
Old 03-06-2022, 12:39 AM
I had my trim wrapped in satin black
180 bucks and it looks amazing
Tahoe Dave
07-01-2020 02:45 AM
beady
11-25-2014 11:47 PM
QuikCat
09-27-2013 06:01 PM
racer9816
09-02-2013 12:24 AM
Quick Reply: Black trim
