Blocked catalytic converter symptoms / diagnosis
Looking for advice on how to tell if my cats are blocked,
What is the normal running temp reading via OBD2 for cats on 5.0 XKs?
After the car heats up from driving in traffic, acceleration becomes poor and
at idle I don't feel much pressure coming out of the exhaust tips, fuel trim goes -10 at idle.
What's the best was to diagnose?
I've done the borescope thing and it was definitive - there were chunks laying inside the housing.
Get a Laser Temp Gun and check the exhaust temperatures immediately before the cats and after the cats. The catalyst housing itself will be much hotter during normal operations. If pre-cat temps are way high compared to a ways after the cat, you have problems.
You could also remove the Fuel/Air sensor (the front "Oxygen Sensor" is actually a fuel-air sensor, the aft one is Oxygen) and see if you get a LOT of exhaust exiting. Your vehicle will not run well in this case however.
trkyam (12-09-2023)
You will get a CEL for that cat in that case. There are ways around that though, like using a Sensor Extender or whatever they are called. Those are a tight fit on these cars.
Received 1,123 Likes
And there was a big “bang” sound. It was not a back fire. Engine was fine, though rpms dropped, engine light on, but it recovered. I’m guessing a build up of pressure has to release somewhere.
Anyhow, its like a filter. Reuse any filter for a long time and report on the flow. At 160,000 km, I’m contemplating its time for #3. Kat Klean needs to be applied every mo in the summer to keep away the check engine light when I floor it now. And I never want to experience that BANG again.
I’ll tell you one thing, once its changed it’s invigorating. Car is happier, more efficient, more vigor.
And I walk a different path than many gearheads. I wouldn’t scar mother nature by removing it.
Cee Jay (02-07-2024)
Joeegillaspy
17
07-29-2013 10:35 PM
bobby181
09-20-2011 09:42 PM
