To Bloody hot. Air not working
A generic code reader will not show climate control faults. There are about 40 Jag specific fault codes associated with the climate control that will require a reader that will read codes from more than the ECU. I assume the SDD will read them but don't know for sure as I don't have an SDD, yet. Can someone with an SDD confirm?
I would start by getting someone to put a set of gauges on the compressor and see if there is refrigerant in the system or not. It is not surprising to have a 10 year old car loose its charge. If low charge is the problem a shop will want to find and repair the leak before charging it. There are laws to that effect in the US. I don't know about Canada.
If you are so inclined, you can get a set of gauges for less than $50 and check this yourself and charge it if needed. DON'T blindly charge it without monitoring the pressures. A new charge may last another 10 years, or not.
If it's low on refrigerant, find the leak. The system should be air tight and should not leak refrigerant. If it does, a simple recharge is just a patch and your still leaking.
Let us know what you find please.
There is a small solenoid that actuates an internal vane in the compresor. I cannot hear anything happening when the compressor cycles on and off.
Sean W (07-02-2017)
Thanks to the guys who replied. Yes the airflow is working fine ,cant hear any switches kick in . the condenser is clear of garbage, has not been recharged ever. only 15k miles, forgot to mention car has not been driven for last 18 months just started now & then , I will have to take it in and get it done.
Given that you're just pulling her out of storage, the shop will probably dye check for leaks and hopefully all you need are a seal or two and a recharge.
Queen and Country (07-06-2017)
Did you get this fixed? Having owned my '07 XK for 3 months I tried the a/c last month but found it wouldn't blow cold. Despite the fact it has a full Jaguar history, there's no evidence it has ever had a recharge - in a decade.
So I booked it into a local garage who have the necessary a/c equipment. Whilst I waited, they identified there was no refrigerant in it at all - all leaked out over the years. They could see no obvious defects, so proceeded with a recharge and leak test, which was satisfactory - it's now blowing cold, as it should.
A relatively cheap solution, completed in about 90 minutes.
Regards
RM
Find another place to store and host your pictures on the Internet I guess or pay PhotoBucket $399 per year.
This thread was one discussing the issue and the person in post 8 used Tinypic:
https://www.jaguarforums.com/forum/o...osting-184928/
