Blower Motor
Blower Motor
Hi I have searched and found a thread on getting a new Blower motor. It’s dated 2014 so thing may have changed
it was also a bit confusing
In the UK a Jag one is nearly £200
Rock autos is £62 with shipping and Tax so quite a difference.
the one in the link below states its the correct one but also lists as being correct for many other cars .
For obvious reasons I don’t want to order the wrong and delivered to the UK
any suggestions if it is the correct part
https://www.rockauto.com/en/catalog/...wer+motor,6916
power connector is an important match. I bought a used one on eBay. If mine hadn't gotten wet it would have ran for years. couldn't stand the squeaking after an a/c leak. Anyway, I recommend used on eBay or at the very least, when looking at one somewhere else, compare the mounts and connector to yours AND the one you want to buy.
The following 2 users liked this post by Sean W:
arenaej (09-26-2023),
bgpenguin21 (09-26-2023)
I received a blower motor from a 3 year old F type.
i checked several Jag sites and they listed the blower motor as the same part number for a XK and F Type so I ordered it.
when it arrived It was evident the power connect was incorrect.
I thought I might be able obtain a new style plug and adapt the harness.
I contacted the Jag main dealer and ordered a harness for a F type. PN T2R27883.
it turned out it was a perfect solution as it was an adapter from old to new.
so nothing to do but plug it in
outrageous price of £1
The following 4 users liked this post by Woo5ie:
