Bluetooth module issues, 2007 XK
I've moved your question from XK8/XKR for the earlier two door X100 model to XK/XKR forum for the later X150 model. This is the place to post questions about your model.
Before you conclude that your Bluetooth module is bad, see if it will recognize an old phone that's listed in that Sticky as being compatible with your car. Also, you need to rule out your phone as the culprit, so see if it will pair with another car.
There might be a section in the repair manual about troubleshooting Bluetooth connections, etc. Hopefully, another Forum member can help.
Good luck, and keep us informed
Kuekuatsu07 (09-06-2021)
JimC64
03-02-2015 08:07 PM
