Bluetooth for music
Old 10-09-2020, 04:57 AM
Bill Mack's Avatar
Thumbs up
To finish off my part of this thread, I took the car to Authorized Import Cars in Flemington, NJ the other day to get AUX enabled. It took about 20 minutes for George to run through the steps in the SDD to get the AUX going. At one point, though, the program threw a warning to the effect that enabling the AUX might result in disabling certain of the information displays on the instrument cluster LCD screen. Although the warning was for VINs other than mine, George said there was still a small risk that it might happen on my car. I took a deep breath, and said "go ahead." Bottom line, AUX works as advertised, and no adverse changes to the LCD screen.
I realize that this upgrade is minor compared to others discussed in this forum, but it's big enough for me.
Thanks again to Cambo, JagWrangler/White XKR and all others for their work and help.
V7Sport (10-09-2020)
Old 10-09-2020, 09:18 AM
StiggyMac's Avatar
Originally Posted by Bill Mack
I finally got the Cambo/JagWrangler Bluetooth adapter installed the other day. It took me quite a while to get everything sorted, but the removal and reinstall of the infotainment unit was straightforward. I'm reasonably handy but I never did this before and wanted to take time and do it right. It was the glovebox removal/reinstall that took more time.
During the glovebox removal, I realized that the cable from the damper behind the box had unhooked from the arm on the glovebox door. Until then, I thought the native behavior of the door was to drop open in freefall onto my wife's knees. Live and learn. Unless I am missing something, the design of the cable attachment to the arm is pretty poor. It's easy to see why the cable would slip off the arm with use. I used a couple of zip-ties to secure the loop on the damper cable to the connection point on the arm - I think that will be a permanent or almost permanent fix.
I digress. After the BSA install, I checked to see if I could get a BT signal from the adapter on my iPhone. Success on the first try! Now all I have to do is get my jagshop to enable the AUX option on the infotainment system and I'm in business.
Good call out on the glovebox. Mine also freefalls, which I until now assumed was working as intended. Will take a closer look to fix that.
Old 10-09-2020, 02:09 PM
Bill Mack's Avatar
Default Glovebox Fix
StiggyMac, here is a photo of the glovebox (not from my car but identical to it) showing the key parts for the repair. The damper cable on my car had a loop at the end (not visible in this image) but it was too small to securely fit over the notch at the end of the glovebox door arm. I connected the loop on the damper cable to the glovebox door arm with two zip-ties threaded through opening in the notch on the door arm.
To get to this point follow the below steps from the Jaguar XK service manual (this is from the manual for RH drive cars but you get the idea). Good luck!
Old 10-09-2020, 03:51 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Unless they were using a very old version of SDD it should detect and help you fix it if that happens.
Old 10-09-2020, 03:54 PM
Bill Mack's Avatar
Question
Thanks, but as I said, it didn't happen.
Old 10-09-2020, 09:30 PM
u102768's Avatar
I know but your post gave the impression that things might go horribly wrong for cars within the VIN range so I was just pointing out that SDD has it covered.
My old '07 XKR was in the VIN range and I flashed it many times without issue.
The following 2 users liked this post by u102768:
Bill Mack (10-12-2020), guy (10-13-2020)
Old 10-09-2020, 09:51 PM
Received 4,464 Likes on 2,427 Posts
The rectification procedure is pull the fuse for the instrument cluster, and put it back in again when SDD tells you to. I've had two cars in that VIN range, but only had to do the rectification step on one of them.
The following 2 users liked this post by Cambo:
kj07xk (10-09-2020), u102768 (10-09-2020)
  #28
Old 10-12-2020, 05:19 PM
RWS1965's Avatar
Where is there a USB slot on the 07, Ive been all over mine the last 2 weeks and have never seen one.
Old 10-12-2020, 05:26 PM
RWS1965's Avatar
I have an 07 and will be buying the best option the Jag wrnglers bluetooth device. In the mean time I ran the L R connection to the AUX in the glove box, then I ran the male jack behind the console and up where it sits tucked beside the drivers seat. Works very well.
  #30
Old 10-12-2020, 06:01 PM
Bill Mack's Avatar
There is no USB connection in the stock 2007 XK. At that time, Jaguar offered an upgrade called the ACM - Audio Connectivity Module - that added a USB port.
  #31
Old 10-13-2020, 12:41 AM
u102768's Avatar
The optional upgrade for the early cars introduced a stereo aux connection and an iPod connector. The USB port didn't get added until the ACM became standard equipment.
Bill Mack (10-13-2020)
  #32
Old 10-13-2020, 05:12 AM
Bill Mack's Avatar
I stand corrected.
Cambo
03-30-2023 04:18 PM
dsd
01-23-2018 07:27 PM
Parmjit Chohan
01-27-2016 02:33 PM
Zachci
07-25-2014 01:47 PM
jontippy
10-04-2010 07:48 PM
Quick Reply: Bluetooth for music
