borla pro-xs mufflers on otherwise stock system results...
I had a pair of borla 14" pro-xs mufflers and borla dual tips installed on my 07' xkr yesterday and i'm not that thrilled with the results.
even with the stock 2 mid-mufflers in place, the car still has a pretty decent amount of cabin drone between 1300-1800 rpm. it's too much for my liking and def too much for my wife. it sounds good overall apart from the drone, but it also isn't as sexy as I had hoped for. it seems as it I've lost a little of the stock (fuse 19 removed) pop and gurgle on decal. that classis overly deep borla tone s there and the car just doesn't sound to great in the upp-rpm's. I was hoping for more and better.
I am going to install 4 of borla's venturi's before and after the muffs, that they claim will knock-out most of the drone. if it doesn't, i'm looking heavily at dynomax's VT series no-drone mufflers. I just cannot take drone and i'm looking for a more aggressive sound too than what the borla's are giving me.
I wonder if I should consider removing the 2nd mid-muffler to achieve some more of the burble and pop and to up the db a tad. that won't help the drone issue, of course. thoughts?
I just installed a Spires Stage 3 active in a friends 2010 XKR. Wow was I impressed. No drone when driving at highway cruising speeds. It almost sounds to quiet but you will then get a slight burble to remind you something is different. If you jump on the gas or select dynamic mode all hell breaks loose. The smile will never come off your face. The system is like a piece of art it is so well made. It is a classic example of you get what you pay for. The installation is straight forward, everything lines right up. I was just overwhelmed at the high quality. If I had bought had bought an XKR instead of an F Type R my car would have the system installed. Just my 2 cents.
my car has zero drone after about 50mph in 6th gear, so highway and back roads are perfect. it's only around town at low rpm. it's not bad, i'm just very sensitive to drone. I think the venturis will cure it. if not, i'll try some other mufflers. i'm not spending silly money on a mina or paramount. two good muffs can work well and are MUCH less expensive.
I have the performance exhaust on my 2012 XKR and I get a drone in between 45-50 MPH. To be exact if I put it on CC at 48 MPH the drone is there. It's not the tires and nothing is loose in the exhaust system so I am assuming it's the exhaust. I do a lot of around town driving and unfortunately it is in that speed range. As soon as I hit 50 MPH it is completely gone. I'll have to check my RPM at that speed to see if it is in that 1800 range. Oh this is in 6th just cruising down the road. If anyone knows the cause or how to fix it I would be interested.
This might not be the same issue, but I'll bring it up for the off chance that it is relevant.
When I'm cruising at 70-80 km/h (43-49mph) I get an annoying drone, but only when I'm in 6th gear. The car is constantly on the edge of downshifting, but the gearbox insists on trying to stay in 6th. If I downshift manually, the revs go up a bit, and the droning goes away, but it eventually shifts back up to 6th. If the noise bothers you, maybe put it in sport mode so you can manually select 5th for those speeds?
Exhaust drone is a big problem with most V8 motors, particularly Chevrolet Corvette and Jaguar. These mfgs deal with drone vis a vie an "active exhaust' which in effect is two exhaust systems - a drone free conventional big muffler system which opens up upon demand to a loud performance system. Some after market mfgs try to deal with drone by a helmholtz (sic) chamber. Dynomax's VT muffler has a spring loaded flap, much like the XK's muffler, which deadens exhaust sound with the flap partially closed and which opens for a flow-through muffler upon demand.
I had Dynomax VT's on a Hyundai Genesis RSpec for 30K miles before I sold it. They eliminated drone almost completely and were trouble free.
Road testers are raving about the new F's exhaust. Check out it's part fiche - the rear muffer looks exactly like the XKR's, but different part number. Center mufflers are deleted and replaced by a shallow "X", which is available from Dynomax.
Before laying out big bucks for a gleaming aftermarket exhaust, I would modify the XKR's with a Dynomax "x" pipe. Then I would add an electrical switch to the vacuum pump which services the rear muffler. By doing this I think exhaust sound would be very close if not identical to a V8 "F". If I didn't like the system I could reverse it or then spend the big bucks on an aftermarket system.
From the views of a parts fiche, the mufflers appear to be identical. Part number for a 2012 XKR muffler is C2P2465, and for a 2015 "F" is T2R14179. Cost is well north of $1500 each.
I think that much of the burble, crackle of the "F" exhaust is due to the shallow "x". Note, it is not a true 90 degree X like that sold by Magnatek. It is more like a shallow balance tube. This would me my first mod. I think a budget of $200 for this is doable.
I think the XKR and F may have different control settings. I have the CD disc shop manual for the 2007. Here is a direct quote from the 2007 CD:
"The active exhaust system is controlled by the ECM. The ECM controls a vacuum control valve which in turn applies a vacuum to the active exhaust valves. The vacuum system comprises:
The active exhaust valves are opened in response to engine speed and throttle angle. At startup the valve is always opened to give an enhanced sound."
"At engine speeds above 4000 RPM the valves are open independent of throttle angle. The active exhaust valves are either open or closed they do not partially open."
The vacuum pump contraption is located in the inner left rear fender. The vacuum pump is electrical, receiving a signal from the ECM. If you interrupt this signal with a simple switch you should be able to open the exhaust valves at will and be able to retain the quieter sound at cruise levels according the ECM program. No doubt the F has different ECM programming, so consider this a "work- around".
- A vacuum reservoir
- A vacuum pump
- A control solenoid
- a vacuum check/non return valve
- a vacuum restrictor valve located located in the vacuum line just above the check valve.
........ The vacuum pump is electrical, receiving a signal from the ECM. If you interrupt this signal with a simple switch you should be able to open the exhaust valves at will and be able to retain the quieter sound at cruise levels according the ECM program. No doubt the F has different ECM programming, so consider this a "work- around".
- A vacuum pump
The valves are controlled by the ECM, based on RPM and throttle opening. The RPM parameters are different between the 4.2 and 5.0 XKRs, and may well be different again for the F-Type. For the 5.0, selecting manual gearchange (by pulling a paddle) or switching to Dynamic Mode with the DSC button will also open the valves.
I didn't find one from dynomax that was the right shape, but this one from magnaflow looks like it would do the trick. would this one be considered shallow?
http://www.summitracing.com/parts/mpe-10791
Dynomax has several "X" pipes. I think the X pipe that the F uses is just a simple shallow X, which is more a balance pipe than a true crossover. The Magnaflow under Summit 10791 is more of a true "X". Borla also offers a shallow X design on many applications.
Here is what Summit Racing sells on Dynomax:
http://www.summitracing.com/parts/wlk-53716
How did you modify your rear box?
I want to do the same!!
https://www.jaguarforums.com/forum/x...-sound-184600/
so far I have resonator delete, and X pipe installed
jagent
09-07-2015 05:00 PM
