Brake Bleeder Screws
Hello All,
I've decided to swap out my brake bleeder screws for speed bleeders, I used Edelbrock 639630 which fit perfectly on the rears and worked like a charm. They are the same as SB1010s, but more readily available; the specs seemed to line up so I rolled the dice and it paid off. Theoretically the 639630 and SB1010s should work in all four calipers on our cars, some people have fitted the SB1010s to all four. The fronts on my car however, are a completely different size, which is contrary to everything I've read. Then I noticed that all listings online for bleeder screws are for rears. Does anyone know what the thread is on the fronts? My car is a 2007 base convertible with standard brakes.
A relevant thread from 2014 covering similar discussion of speed bleeders:
https://www.jaguarforums.com/forum/x...10-xks-117924/
