Brake Bleeding and Flush... How soft of a pedal?
Changed brakes and rotors all the way around on my XKR, had to crack off a caliper to have enough torque to retract a piston. So I lost fluid, and did a brake fluid flush all the way around, bleeding out and replacing little more than 1L of fluid.
However, I still feel like my pedal is still too spongy. Should I go do the flush again? Or is that just how it is on these cars and I'm being neurotic?
If we are talking static peddle pressure it should be no different then before you did the brake job. If softer pads are used then you would feel a difference in braking performance but the peddle pressure should be the same. A soft peddle is a sign of either air or water in the system. If there is air in the system it does not or cannot work it's way out as it is a closed system. I would get a power bleed done . Just my 2 cents
Sean W (05-16-2020)
I would do another flush starting with the right rear caliper. I usually push just over a litre of fluid through the full circuit. I have been changing pads on all of my cars for over 20 years and in my experience new pads and new rotors actually make the pedal feel firmer. But I also bed them in first to get full benefit from the Replacement.
I find the easiest way to do it by myself is to fill and pressurize the reservoir with a power bleeder and then open and close the bleeders one by one, the old fluid is pushed out automatically.
The following 3 users liked this post by jahummer:
You must open the bleeder all the way and close it while the new fluid is flowing and you see no more bubbles. You want to do this rather quickly so you don’t create a vacuum in the bleeder and suck bubbles back in. No worries though, It is easier than it sounds.
