Brake Caliper Painting
Surely there are some custom pro shops around big D, Go to the places that deal with the rice burners..they have all sorts of line up of people that would know where you can get it done., I know we have em up here in OKC....I personally would paint them myself with some Caliper paint in a rattle can..I see it on ebay all the time.
ORIGINAL: bd6047
What is a rice burner ?
Per Urban Dictionary:
Rice Burner
What every 16-20 year old who's seen "The Fast and the Furious", or "2 Fast 2 Furious" is likely to drive. Usually running a ridiculous amount of negative wheel camber due to the car being lowered without getting an alignment done, wheels larger than can reasonably fit in the wheelwells (giving lots of tire rub), a 3 foot tall aluminum wing, under car neon tubing, "Type R" decals, a boost gauge (esp in a normally aspirated car), and has the overall appearance of an automobile onto which every advertiser in Super Street has barfed a part.
Required equipment includes a 5 inch exhaust tip on an otherwise stock exhaust system, a 4 million watt stereo system that, from outside the car, seems to do mothing other than vibrate the rear hatch glass, and every aftermarket gauge that the local Pep Boys carries (not necessarily connected to anything).
Not to be confused with a "tuner car", which may be quite a bit faster than anything you've seen away from a racetrack
LOL...
Rice Burner
Rice Burner
I painted my calipers, about 30 days ago, with Rust-Oleum "Hammered" spray paint, on the car with minimum prep. L00ks great if you want factory new look.
Contrary to conventional wisdom you do not need special caliper paint if you are not on the track and drive below 100 mph. This product requires no primer. Merely clean calipers with Brake Cleaner, carefully mask off the disk, etc and have at it. Available at Wall mart.
danke (09-16-2015)
wvanepps
10-04-2015 10:01 AM
