Brake dust solution.
There have been plenty of posts about the excessive brake dust from OEM pads. And perhaps my solution has been posted previously but here's something I just tested. After washing the XK and the S-Type and spending a lot of time on the wheels, which were black with brake dust, I tried a can of Armorall Wheel Protectant. I followed the directions and made sure the wheels were completely dry before spraying on the Armorall. I then let the cars sit for a couple hours. The next day I had to drive about 80 miles and the day after, a round trip from east coast to west coast of Florida, another 370 miles. When I got home, the wheels still looked great. To be safe, I rinsed them off with the hose but very little dust appeared to be in the runoff. I think the stuff works.
Is the idea of the protectorant that it will provide a more slippery surface to which the dust doesn't stick, because it obviously does not affect the amount of brake dust coming off of the pads. I have tried waxing my wheels to make them slicker, but it doesn't seem to affect the excessive amount of dust that comes off of the OEM pads. I just find that if I want clean looking wheels, I have to get out and wipe them every morning. P.I.T.A.
I tried that Armorall product on my wheels. It left white streaks, although I really tried to apply it as light as possible. It only lasts a little while and I still had to scrub the wheels to get them clean of brake dust.
I use other Armorall products but I think the folks at Armorall really missed the mark on this product. Total wast of time and money, IMHO.
For $7 per can (and it takes almost a whole can to do all four wheels) I decided to invest in some Akebono ceramic pads instead.
Vector
Vector
amcdonal86 (06-19-2013)
Vector
Vector
tnt
Maybe if you had carbon fiber rotors or something exotic like that, but I don't think you are going to be choosing your own pads on your Enzo.
Ceramic pads have been around for a long time for street and track use and Akebono Euro ceramics have been used by a lot of members with good results.
Vector
Ceramic pads damaging the rotors? Never heard that one.
Vector
Vector
jagxk2008 (04-29-2013)
Before I switched to ceramic pads (with good all around results) I used wheel protectant products with excellent results. Eagle One makes a good product (Keep clean Wheel) for one. I was able to do 16 wheels per bottle. If the stuff runs and produces spots you are using much too much.
I still use the products from time to time because it makes my "silver sparkle" wheels gleam like nothing else.
I am concerned cause I don't want say the brakes saved me once or twice already but yes they work excelent now and twice I was really a bit late and I appreciated their effects.
Which Are The Best Brake Pads - Ceramic vs. Metallic - EBC Performance Brakes & Rotors
With the confusion I will buy eagle one and wash my wheels...
but in case, which Akebono pads fits the xkr 2010?
Being under the 2011 wear and tear warranty, the dealership told me they won't let me substitute pads and the free brake jobs require them to install factory pads. Bummer.
I've been using the armor all wheel spray, but the results, while better, are still bad. The rims look filthy after minimal driving, and I don't have a setup where I can easily get a hose on the rims to rinse them off...
I'm going to enact the ultimate sanction and plasti-dip the rims gloss black and see if that doesn't make the dust harder to notice
A severe solution, but the dust KILLS ME with the quickness it accumulates. Never seen a car that generates so much dust that sticks so badly. Awful!
If the black rims look bad, I'll get some gasoline soaked rags and wipe the plasti-dip off. Good to know I can go back easily. Worth a shot I figure.
Skeeter
Skeeter
I guess they are saying what they want cause here they said ceramic are better on the rotors...
Did you ever find an answer to this question, because I have yet to find it. I loved the Akebono ceramics on my 2004 XJR, and would like to use them on my 2010 XKR, but can't find them anywhere, including on Akebono's website...
The harder your brake pads are, the more the rotors will be worn and gouged. Regular iron rotors will get more wear from ceramic or Kevlar impregnated pads (like the EBC Redstuff pads). Also harder pads don't have the cold braking ability or the regular street braking performance that the softer semi-metallic pads have, and one should be cognizant of this when driving.
I've found that since I painted most of my wheels black I don't see the brake dust a much...
My recent experience is that ceramics can cause your rotors to warp. Perhaps it depends on the brand, but, Akebono does not make front pads for 2007 XK. I went with Wagner ceramics and half way through my pads the rotors warped. Not worth it to me for dust less wheels. Changed my rotors and went back to OEM pads. Just not worth it to me.
