brake fluid change?
bobdr1 (05-19-2014)
Service manual recommends brake fluid change every 15,000 miles or 2 years. I had mine done recently by Jaguar with an oil change and I only had 6,000 miles. I think it was $99. You might want to have it changed to avoid any warranty loopholes by the dealer down the road.
bobdr1 (05-19-2014)
I would have to pay for it, agree that it probably does not need changed but if it is less than $100 for warranty issues , as bocatrip points out, probably better off doing it.
The problem is moisture in the brake fluid. It lowers the boiling point of the brake fluid (probably not a big deal on a street car) and can cause brake parts to corrode from the inside. I had a brake caliper seize up on my Miata. Not so much fun!
Of course, some people swear that brake fluid never needs to be changed and that this is all a thing of the past...
I don't think the brake fluid has ever been changed on my 2007 XKR. It's on my list of things to do (but will probably never get to).
bobdr1 (05-21-2014)
WRONG. NEVER WAIT FOR FLUID FAILURE. Brake fluid is probably the least attended fluid in a car. 3.5 years is TOO long for a non synthetic factory product. Even Valvoline Synthetic gets done every 2-3 yrs in all my vehicles. Just did my new 2012 XK with only 7800 miles. Bottom line-->BRAKES FEEL BETTER INSTANTLY.
See my Speed Bleeder post.
Lessons from my track days.... I know Exactly what boiled brakes feel like, and having your peddle sink solidly to the floorboard as your charging a turn at 100+ make you appreciate the real science behind how brakes and brake fliuds work.... Two other things gained my appreciation that day.. One was the track designer that put the emergency runoff space on that curve, and the other was Tides ability to remove stains from my my underwear.
From that day forward, I have treated brakes with the utmost respect, and I never even consider going "cheap" on such critical safety equipment. I now flush brakes yearly...
I am always stunned to hear how people with any car, not just this level of car, can be so cheap as to not care about safety equipment or manufacture recommendations. For goodness sakes, a flush is $150 every two years....Be cheap in your next bottle of wine, but not here...
ddsski (05-23-2014)
Wes Steenrod
09-06-2015 06:52 PM
