Is brake fluid change necessary every two years?
#41
Received 2,263 Likes
Caliper seizures can be caused by many things other than contaminated fluid. Dust shield failure allowing dirt/salt/water ingress is the most common.
#43
#44
I have become the devils advocate on this subject. I am not advocating not changing the brake fluid, but rather that 2 years is overly conservative. Many years ago (1970's) I was a chassis engineer with one of the Big 3. Co-works who were responsible for brakes told me that brake fluid change was based on the worst case scenario of someone checking the brake fluid every time the oil level was checked (which was every fuel fill)...and the location was humid Florida. They would say "if there is some way we could prevent them from pulling the lid off the reservoir we could extend the fluid change interval. Well that is now the case. How can 2 years still be the same change interval as it was in the 70's when we constantly opened up the reservoir to check the fluid? OK, maybe that is what the manufacturers insist on (their legal depts. want to cover the worst case scenario). When I stopped doing my own maintenance in the 80's (changing brake fluid was a pain) I had the dealer change the brake fluid.....and experienced poorly bled systems several times. Buying a new car every 5 years I just gave up on changing the brake fluid. Since I bought my '04 Lincoln LS I decided not to change the fluid and have not had any issues. I'm a sample size of "one" which is of no statistical consequence, but it will be difficult to convince me that a 5 year change interval in a dry environment is wrong. OK, maybe 4 years to placate the attorneys. But 2 or 3 years...be my guest. BTW, amcdonal 86, how old was your Miata when the brakes seized and what were the symptoms of the seizure (failed to brake or locked up)?
Another PS: my neighbor has an '08 car with over 90,000 miles and has never changed his engine oil. As wrong as that is, maybe I'm doing the same thing with my Lincoln's brakes. So, who am I to say. Hey, change your brake fluid every 2 years...forget what I said as nobody agrees, I'm just the guy who saw a flying saucer in my backyard.
Mikey (08-14-2013)
#45
#46
#47
#49
I once had a 54 Buick that lived in Alabama. In the Winter of 60/61 (maybe 61/62) we had a freeze where the temp dipped below 20 degrees F and for 3 days. We thought the world was coming to an end.
Anyway, that car's brake fluid froze and locked the brakes for a week together with 100s of other cars in Huntsville. Some lessons come hard.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
#50
Anyway, that car's brake fluid froze and locked the brakes for a week together with 100s of other cars in Huntsville. Some lessons come hard.![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Cars since the late '60s-ish have had sealed master cylinders that isolate the fluid from the air by using a diaphragm or bellows. No more air entering the chamber through normal use.
In those days, we used to open the master to inspect the level on a frequent basis and add fluid as the shoes wore. Today's cars have see-though reservoirs and contain enough fluid to accommodate 100% wear on all four sets of pads- each of which obviates the need to remove the cap.
BrentGardner
28
04-26-2024 03:08 AM
