Brake fluid reservoir
Hi . I want to remove the brake fluid reservoir so I can get to a wire connector which is located under the master cylinder. I cannot get my hands in with the reservoir there.
The wire connector under the master cylinder keeps buzzing, I presume it has got water in it as it is directly below the water run off from the windscreen. Can I just suck out the oil from the reservoir and remove it and then refill when I replace it ?
Any info will be help fully
thanks in advance Chris
Received 1,179 Likes
badicedog (09-23-2019)
Hi Jahummer. Cannot see any other way of getting to the connector. Can just about get one hand down beside the master cylinder , cannot get in from the bottom . The wire makes a loud crackling noise , I presume because it has got damp or is shorting out someway. Any suggestions welcome, could possibly take a photo to show you.
regards Chris
regards Chris
joeleerj
11-27-2016 06:37 PM
