Brake Light warning wont clear
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I currently had a passenger brake light indicator warning and I replaced the bulb. I currently have all the brake lights working fine, but the warning indicator will not clear, I have fiddled and replaced with another bulb, but the indicator remains..Do I have to replace the drivers side bulb as well or is there a reset that will clear this...Of course My warranty just ended last month...
any help would be appreciated
al
al
That's weird. I didn't need a code reader to clear the brake light warning on mine. Mine cleared immediately when I installed a new bulb. The bulbs I originally bought at NAPA were some cheap generic ones that would blow within a few weeks or so. The parts guy eventually found some other bulbs that cost a few cents more and those have worked perfectly for the past year.
When you swapped the bulb out with a different one, was it the same brand/model bulb? Just wondering if you got some crappy bulbs like I did
I had similar... Brake light warning... Replaced bulb and the warning remained....
Fiddled with it a bit, including swapping bulbs from left to right sides. Still got the error regardless.
After swapping out to a different brand it mysteriously went away...
I was flustered enough to just be glad I was done with it, and never troubleshot further....
BOL
Vince
BOL
Vince
So after reviewing the post, I went to the auto parts store and had them look up the correct bulb, the better ones they had in stock were Sylvania. I put them in and the the warning light disappeared.. It shows that you really cant use cheap parts on a XK... Thanks for all the help, and use the correct bulbs for your jag if you dont want the headache..
thanks again
al
thanks again
al
thanks again
al
thanks again
al
99xk8guy
06-05-2023 06:28 AM
