Brake noise - can I say "fart" on this forum?
My brakes make a noise that sounds like a little fart milliseconds before they complete a stop. I videoed it going forwards and backwards.
They have always done this in the 10 months that I have owned the car. It seems to be worse if I have just cleaned the wheels, perhaps getting the rotors wet? And the only time I've noticed that it goes away is when I've driven the car pretty hard for a while. Perhaps brake dust accumulation? Perhaps heat?
I asked the dealer about it the last time it was in for service, and he said it was just a normal rubbing noise and rubbed his fingers on the glass to demonstrate the concept. I got it. I guess that is what it sounds like, but none of my other cars have done it. Is there something different about these brake pads? By the way, both the pads and rotors were fine, and had plenty of life left in them when last checked.
I'm actually pleased to see from the video that it's not as loud from the outside as it is from the inside. Inside the car it sounds much louder.
And, yes, many racing brake pads would be very noisy; they sound like a big grinder wheel against metal, which is what they supposed to be.
Albert
Stuart S (01-13-2015)
I would request from the dealer to check all brakes for bolts being tight and if nothing loose found, lubricate the back of the pads and see if that eliminates the sound.
Good luck,
Albert
Muddydog (09-01-2013)
Something is not right. Take it to the dealer and have them fix it before your warranty runs out. That would definitely bother me. I would not live with it. If my car made that noise, and the dealer told me to live with it, I would have a ****-fit at the dealer. They know better than to tell me to live with it. Let us know what happens--I'm interested in your outcome and what the dealer is going to do for you. Before I bought my 2013 I followed Lothar52's chirp problem and put my next Jaguar purchase on the line. I would have never bought my 2013 or any other Jaguar if they never fixed Lothar52's problem to his satisfaction.
I know this thread is old, year and a half or so, but wondering if this was ever resolved. I listened to noise, and can't tell if it is the same as mine. With my 2004 XK8, when I stop, just prior to the point of a full stop, my brakes sort of vibrate, which I don't think is too unusual, but they do it longer and more pronounced/louder than any other car I have had. You know when you are stopped and barely have your foot on the brake pedal, and the car sort of creeps a few inches, it is that noise and feel. Well anyow, I have had this issue for 50k miles, even after new rotors and pads. I just thought it was normal. Last week, totally unrelated, I replaced my shocks, as the lower shock bushings were worn, and have been for a long time, I just never got to it. So after I replaced the shocks, this issue is 98% eliminated, except for a very very slight and innocuous noise Barkley perceptible - sometimes. I did the shock replacement myself. I also replaced the inner and out tie rods and steering rack boots. So all I can say is I think these parts are a factor, and if anything, the shocks, as the tie rods were replaced only due to one inner tie rod being bent. I can't understand why this fixed it.
Muddydog (01-13-2015)
innzane
09-02-2015 10:08 AM
