Brake pressure bleeder recommendation
Received 2,627 Likes
The following 2 users liked this post by NBCat:
GordoCatCar (10-17-2017),
JagV8 (10-17-2017)
I rigged up a true pressure bleeder on my "05 XJR" using my air compressor and a modified brake fluid reservoir fill cap. It did not work out very as the reservoir was not air tight. Don't ask if it was just that particular reservoir or Jag reservoirs in general because I don't know.
I will tell you that I had a bitch of a time bleeding the brake system on my 07 XK. The trick is to be sure that when you finish the rear and move to the front make it a point to go to the front wheel diagonal to the last wheel bled in the rear. Only then was I able to get a good and proper bleed of the system using my vacuum bleeder kit. Something to do with the dual diagnoal brake systems of modern cars I'm told.
See here: https://www.jaguarforums.com/forum/x...10-xks-117924/
Also, I successfully - by myself - used speed bleeders on my 2010XK; piece of cake: I previously had called the company, and they indicated SB1010s for the front 2010 XK, or the version in stainless steel, but guessed at the rears. For 2009, the SB1010s are the size. Based on the above link, SB1010s are good for the 2010. all around.
Update: Based on me doing the bleeding of my XK 2010 brakes, the SB1010s are the correct size all around.
~wrair
~wrair
JagV8 (10-17-2017)
~wrair
~wrair
I flushed mine a couple weeks ago using a Harbor Freight compressed air bleeder and it was a total snap. I didn't even have to lift her up to get it done. I had tried the hand vacuum from them but found it more of a hassel and the bottle too small.
It came with a resevoir adapter but I opted instead to just to remove most of the old fluid then keep it full of fresh juice in the process. I was careful to make sure the fill cap area was clean plus not getting anything on paint.
Appreciate all the input but not really interested in speedbleeders. I have had them on other cars but was looking at trying out the pressure bleed option. Just not able to confirm weather their caps will
fit the Jag master cylinder. CEEJAY I assume that the one you purchased from Amazon fit your 2010 XKR so should fit my 2012 XK. Thanks again for all the input.
I didn't use the resevoir auto filler so I don't really know if it fit or not.
https://www.harborfreight.com/brake-...der-92924.html
Sean W (10-18-2017)
The one I use, works perfectly.
https://smile.amazon.com/BikeMaster-...PNR059XC0PY4WG
