Brake question
I guess we are disussing two different setups now ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Changing pads and rotors on these cars is not really any different from any other cars. The Allen key sizes are sometimes not ones that are usually in a basic set, but otherwise easy: Don't put the park brake on and ideally disconnect the battery so that the park brak cannot operate and squash any fingers.
The wear sensors go brittle with time/heat and are not always reusable. A spare in stock before starting is a good plan. Aftermarket ones are so cheap, I would always just replace them with the pad swap.
A good starting point is this thread: https://www.jaguarforums.com/forum/x...job-how-85582/
The cars with Alcon brakes appear to have an additional caliper. In that case there are two calipers to remove. The rest "should" be the usual procedure.
The E-brake is a big nothing. All you do is NOT set it when you last park. Yes, there is a procedure to set/release/reset the E-brake, but it's really not necessary unless you do something else, like new different rotors or something. Replacing the E-brake pads would also be a time to do it. But, who ever changes those?
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x887/ebrake2_c7f44c1157c8f9df43b1a51498d3eab95ae3819f.jpg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x462/ebarke3a_21f5f23947ab23b8fc782f932a5d44b9a2ab1487.jpg)
If (I don't know) Alcons have a separate shoe on the rear of the rotor, that wouldn't have any conditions about wear on a disk, as those shoes don't actually WEAR, unless you drive a lot with the E-Brake engaged.
I may be wrong, but it only makes sense.
Bad Cattitude
02-22-2013 07:43 AM
