Brake question
I guess we are disussing two different setups now
Changing pads and rotors on these cars is not really any different from any other cars. The Allen key sizes are sometimes not ones that are usually in a basic set, but otherwise easy: Don't put the park brake on and ideally disconnect the battery so that the park brak cannot operate and squash any fingers.
The wear sensors go brittle with time/heat and are not always reusable. A spare in stock before starting is a good plan. Aftermarket ones are so cheap, I would always just replace them with the pad swap.
A good starting point is this thread: https://www.jaguarforums.com/forum/x...job-how-85582/
The cars with Alcon brakes appear to have an additional caliper. In that case there are two calipers to remove. The rest "should" be the usual procedure.
The E-brake is a big nothing. All you do is NOT set it when you last park. Yes, there is a procedure to set/release/reset the E-brake, but it's really not necessary unless you do something else, like new different rotors or something. Replacing the E-brake pads would also be a time to do it. But, who ever changes those?
If (I don't know) Alcons have a separate shoe on the rear of the rotor, that wouldn't have any conditions about wear on a disk, as those shoes don't actually WEAR, unless you drive a lot with the E-Brake engaged.
I may be wrong, but it only makes sense.
Bad Cattitude
02-22-2013 07:43 AM
