Broken rear wheel stud on x150
Greetings from Ireland, I have just joined up as I am now the proud owner of an XK and an XJ and will need help at some stage in the future.
I tried to search how to replace a broken rear wheel stud on my XK (x150) by going to the Jaguars Modern section and then failed miserably so .....
Can anyone help?
Is it possible to do in situ with a grinder and some swearing
or
Does it all have to come apart to be replaced on the kitchen table before diner
or
Is it a replacement hub assembly (ouch)
Any re-direction would be appreciated to previous threads and ... obviously
advice on how to search this wonderful forum ...
Can anyone help?
or
or
Welcome! I am very new too, but I saw this thread and thought it might be of interest to you. So far, I have not had to work on my car, but I am now on my 3rd week of owning it.
Best of luck with yours!
https://www.jaguarforums.com/forum/x...-bolts-145997/
Relevant part is a Moog 512540, sourced some pics of the hub assy for reference.
https://www.opticatonline.com/part/m...d-hub-assembly
So, the correct way is to pop the hub off and press the studs out followed by pressing a replacement back through the hub. This is more work to remove the axle from the hub and the hub from the mount. Plus you really need to make sure the axle nut is torqued correctly. You can also drive the stud out once the hub is free by setting the broken stud over a length of pipe or deep well socket and drive directly from the stud through the socket to avoid damaging the bearing.
Not so correct is to drive the stud out and use a stack of washers and a lug nut to draw the new one back through the hub. This works but is hard on the bearings and you may not have enough clearance between the mount and the hub flange to walk the studs out / back in.
Either way the wheel and brake components need moved out of the way. Not a horrible job if you have the space and equipment to do it. It's a 3-4 difficulty to do and will take about an hour or two to complete.
I have replaced other wheel studs but not on my XKR. I suspect it should not be to much different. The studs are pressed in but it is usually not necessary to pull the wheel hub to replace a stud. I used to knock out the old stud with a hammer and punch. You can grind the stud down to the face of the hub and knock it out. You can also drill the stud and then punch it out. There should be enough room to install the new stud from the rear of the hub. By the way we assume you removed the caliper and brake rotor. I also seem to recall there was a tool to pull the new stud through something like a wheel/bearing puller but I have also used a lug nut with washers behind it so I could pull the stud into the hub. Good luck and keep us posted.
Queen and Country (06-13-2017)
