Bulk Oil
Bulk Oil
I went to Jaguar today for my yearly oil change and requested Castrol Synthetic. On the invoice it reads: 8 55259 5W-20 Bulk Oil. All the previous work orders from the first owner at his PA Jaguar dealerhsip show Castrol Synthetic at the oil changes. How do I know I got the Castrol Synthetic?
Yes I see it. I guess the tech writes up the work sheet and makes important omissions. Well, hopefully I did get the good stuff. I was going to bring my own Mobil 1 but it would have been a wash with Jaguar labor. Next time I go to my independent and save some money. Thanks again.
Use only 5W-20 engine oil, meeting
specification WSS M2C925-A.
I'm not entirely sure that Mobil 1 meets that spec.
It came to a whopping $150 and change. I see $9.09 per quart X 8 for $72.72 for the oil and an outstanding price of $44.36 for a filter? Labor was $29.30 The only reason I went for it, was because I decided on a brake fluid flush as well. I didn't want to give the brake flush to my independent shop and decided to just bite the bullet this time for the oil change. I'm starting an extended warranty and wanted to make sure any required services were taken care of.
richzak (04-16-2014)
Castrol 5w20 Synthetic available at Walmart in 5 Qt containers....makes sense to buy bulk, then have an indy do the oil change...K&N Oil Filter for Jaguar XKR is:
HP-1014 - K&N Oil Filters, Oil Filter direct from K&N
Castrol Edge with Syntec Power Technology 5W-20 Motor Oil, 5 qt.: Automotive : Walmart.com
Castrol Edge with Syntec Technology 5W-20 Fully Synthetic Motor Oil (1 Quart) 06247: Purchase the best Synthetic/Blended 5W-20 Oil at Advance Auto Parts
Neither of those oils meets Jaguar spec WSS M2C925-A.
The Castrol Edge Synthetic 5w20 will still do the job just fine.
Just as well as the K&N oil Filter.
These are high quality oil lubricants and the K&N oil filters are also high quality.
Buying a bulk oil that is pumped from a 55 gallon drum, there is NO way to verify what you are actually getting. The only verfication is what is printed on a receipt.
I am sure that if someone wrote to or called Castrol, they would state this Castrol 5w20 Edge Synthetic oil from Walmart or any other quality automotive parts supplier is an oil that can be used in the Jaguar brand without any problems being reported.
WSS-M2C945-A spec replace the WSS-M2C925-A for motor oil 5w/20
http://www.justanswer.com/ford/5dtom...c-replace.html
If anyone doubts this, show me a report or documentation from Castrol that shows or states that this oil should not be used.
The following 2 users liked this post by richzak:
bobdr1 (05-17-2014),
SoCal Babe (04-16-2014)
I would agree with you with regards to not knowing what you are getting from a 50 gallon drum, but then you can also say that if you give them the containers of oil you purchased, unless you see them pour it from your container, who knows if they are actually using it. There comes a point where we have to trust someone, or life becomes too difficult. When I mentioned and independent shop I was talking about my local mechanic that I've known for years for his trust and integrity. I would trust him 100% and could bring the oil and filter with total confidence. In addition, I personally would only use the factory filter, just in case there are any claims down the road where the warranty company is looking for any kind of loophole.
3jagfamily
10-01-2015 01:49 AM
Woznaldo
09-26-2015 11:02 AM
