A/C condensation drain tube plugged
Need advice. My A/C condensation drain tube is plugged. Called the dealership and there is a new "fix" replacement tube that does not clog as easily. The tube is $19 but the labor is $1,150. That hurts! Rather spend that kind of money on a new pair of tires. What are the options? I heard there is a fix to re-tap a new drain hole. Can anyone help and send photos on how to do this? I have the 2008 XKR Portfolio Convertible. Best, Yenho
WARNING! WARNING! The instructions on the link that Cee Jay posted only partially work. I did it and at first it didn't seem to help at all. Then I built a little "dam" next to the AC blower to stop the water from sloshing into it when I went around a left hand turn. Now, on rare occasions I will still get a few drips if I make a really hard left turn. But I'm 95% satisfied with that solution. I'm satisfied enough that I haven't bothered to try anything else. I plan to fix the drain someday, but for now the bypass tube is good enough.
Nope disagree, Cee Jay's post is spot on and there are many others on the forum that indicate it is the best permanent approach. I tried all the optional approaches on my 07 vert, including a by-pass tube & dam to keep the water out of the blower but still had condensate. In the end I made up a knife on a bent steel rod and was able to cut the 'duck bill' nipple off. I'll admit it took several tries but in the end it worked 100%....no water in the foot well.
Some searching on the forum will get you lots of advice on how others accomplished solving the problem.
Ranchero50 (07-28-2019)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/img_20190731_090905_09591ccace44f03be64a04f4cffbeaecdf8cf937.jpg)
This is the new drain valve at $19. Half of the duck bill... The original full duck bill design is really bad. No wonder it is stuck.
kj07xk (07-31-2019)
Received 1,975 Likes
So why bother putting in a new design duckbill, when you can cut off the old one?
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1206x1014/img_20190801_203027_565c75ec0a4942bd54d6493cb19aec04ec14934d.jpg)
Looking inside the duck bill.
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1623x1972/img_20190801_203050_8c83d93ebd62cfb25584844cca8dd00be3259f52.jpg)
Original duck bill design.
Took me 15 minutes on my 07 xkr to slice and dice the duckbill once I had built a tool to do so. Tight fit between the firewall and intake but doable. Only advice would be once you have sliced it and your car starts peeing on the driveway like a good puppy, keep slicing.
Quebecjag
10-22-2013 08:01 AM
HHIXJR
01-27-2010 11:36 PM
