A/C drain duck bill fix - my solution
#301
#302
Tarokyama, how did you get access to yours - did you cut or move the felt/carpet mat? I tried to get a hand down above the transmission and can only feel the mat above it, seems odd that the mat would obscure the duckbill, wouldn't there be a hole cut in the mat to allow the water out? How is the mat fixed to the firewall, can it be dropped a bit to allow access?
I tried the "fast fans with vents closed" trick a couple of times, on both occasions I got no water in the footwell and loads of it dripping onto the road under the car. Almost as soon as the climate control is set back to auto I get water in the footwell again. This, and a few other current issues, are really sucking the joy out of owning this car for me just now, it's days in my possession may be numbered.
I totally get that the niggles are spoiling your enjoyment right now - but get them fixed and then you will have one of the best cars of its type ever made. And one you can happily enjoy for many, many years, all at a very reasonable cost.
ralphwg (09-09-2020)
#303
Thanks both. barnsie, part of the problem is there is no good Jaguar-specialist indie garage much closer than three hours' drive from here and the local dealer is not great. I ordered an inspection camera which arrived yesterday though, hopefully that will help find the blockage. Going to drop the blower motor and see if I can get the camera into the inside of the unit where the condensate drains out.
#304
Received 2,050 Likes
I seem to recall that when someone tried drilling through the box, or cutting an access hole, they ran into a lot of foam type material in there, so it may not just be ‘empty space’ and block your camera access, but good luck trying.
#305
My car is gladly out of the danger zone for this one, but wondering if laparoscopic scissors or electrodes could help cut/burn open the duck bill?
https://m.alibaba.com/trade/search?S...&from=header&&
#306
#307
#308
A big thanks to all users and the advice given on this thread.
I've had my 2007 XK for a year now and just encountered the water in the footwell issue. After reading through the options to remedy this I have chosen to hand cut the duck bill by hand. Today i've taken delivery of an Endoscope camera ( Lightswim Wireless Endoscope £26.90 from Amazon ) , works brilliantly from my iPhone and has all the necessary attachments.
I will be making some cutting tools and with patience, hope to stop the water coming through into the cabin.
Many thanks to all again and will post my results as they happen.
Chris77 (06-10-2023)
#309
Syracuse jag problems.
Andy,
I guess it shouldn't be a surprise to me that this issue caused exact replication of the same problems... thanks for the tip on the blower motor - add a few more cases of beer and a bottle of scotch to the IOU list. My pal who does all his own work on his 1970 XKE, Aston and Porsche is going to be helping me with the repairs so hopefully a look at your posts and a few tequila shots will also help me get this worked out, too. I'm in Syracuse, NY - way upstate, from the city anyway. Last year we had a break in the weather in late Feb early Mar and I got the car out of storage, only to have Apr be one of the snowiest on record here - hoping that was an anomaly! I don't have any real concern about insects here, so may go ahead and chop that duckbill right off.
I bet that maroon top looks sweet - keep working on him, maybe he'll come down on the price - the matching pair would be awesome!
Cheers,
Mike
Cheers,
Mike
#310
Guys, it can be fixed in an hour, no need to remove dash, no need to drill any holes or removing blower, no need to lower the transmission, no need to buy a camera. All you need is a shapened nail or knifeblade and ducttape. It's in the stickies:
https://www.jaguarforums.com/forum/x...-doing-222930/
#311
PM me if you want to have a phone call and I can talk you through the process and perhaps we can meet up and I can take a look at your engine and see if your process will be similar - you may not need to remove anything - I had to because of the supercharger. Btw I couldn't snip mine, not enough space and protrusion, so I did the lube job - I repeat this every spring when I get the car out of winter storage.
#312
I had another attempt at this tonight, still can't reach the end of the duckbill but I did at least manage to get my inspection camera in this time. Despite my car's VIN being a couple of thousand after the new part was apparently introduced it does look like the old one to me:
I found I was able to get my right hand in furthest by kneeling on the suspension turret, compared to standing on the car. Anyone who's managed to get their hand on the end of the pipe able to suggest any other ways to maximise your reach?
I did wonder, based on something I saw in another thread; if I remove the center air vents on the dash then would there perhaps be a route down to that from above with a wire coat hanger and something soaked in silicone lube on the end, has anyone tried that? Failing that I think I'll get a pair of long-handled scissors and see if I can just chop the end off from the engine bay...
#314
I was able to slice mine up with a home made scalpel found on this forum. The finger mounted blade solution looks the easiest and wasn’t thought of back when I operated on my duckbill. The camera scope really is just used as a visual reference when you go the home made scalpel route. You can feel your way there with a finger mounted blade. If you take the time to research back through this thread, you will learn what worked and what failed. It is worth your time not to repeat our mistakes.
Good Luck!
Good Luck!
#315
Are the '06 models concerned with this duck bill issue as well?
And when it comes to the A/C "preventive" operation: I know one should set the fan to max and close the vents, but what about the other A/C parameters?
Should one set the temperature to minimum? How should one set the air flows?
#316
Don't think preventive operation will help, duckbill will need slicing!:-)
#317
Good Luck!
Good Luck!
#318
Maybe helpful images
Here's a pic of a duckbill from a Jag being used for parts.
And a pic of a 36" scisssors. Maybe use the bore to locate it and the scissors to cut it off. The blades swivel 360 degrees.
Different views of the duckbill
Maybe use to cut off duckbill. 36" long and swivels 360 degrees
fuzzyhippo (08-03-2021)
#319
#320
Still the same problem.
I was wondering if you are still available for a phone call or a meet for assistance with this problem. I am not able to PM due to my newbie status.
Hi Crawford, I actually did the job myself. One thing to note from the posts above is that the 07 xk apparently has a different bill configuration than the 09 supercharged which is what I have. FYI I followed the instructions that were posted by @GR8BR1T above exactly, see post #177.
