A/C problem
A/C problem
My A/C appears to have just quit on my 2007 XK conv. Worked fine yesterday. I had the Aux Fan Temp Switch replaced along with the pressure Sensor in August 2017. Also replaced the cabin filter.
Cannot hear the blower thru the vents, so obviously the fan is not pushing out any air. No cooling either.
My question, Could there be a problem with fuses causing this problem. Don't want to spend another $1300 to fix what appears to be the same problem I had previously.
Can you clarify? Your blower motor isn't working? That could be your only problem. Does the fan blow when you call for heat or fresh air?
Fuse 34 and Relay 1 in the rear Junction box control the fan. I would start there. If you have power at the fuse, the blower motor has a resistor that can blow and be repaired fairly cheaply.
open constantly. Occassionally my valve gets stuck closed..
MySTypeAteMyRX7
12-18-2012 02:43 PM
Turbo_dash
10-09-2012 06:28 PM
kenc
07-03-2010 03:59 PM
GTBentley85
06-10-2010 10:03 AM
