A/C Re gas question
A/C Re gas question
Hi All. I used my A/C for the first time recently........warmer spring weather on its way It was barely cold. I also noticed last summer that it was not getting as cold as it used to.
Is there a window indicator somewhere in the A/C system that will indicate the gas is low or run out. I had a Falcon that had a quick visual inspection window to check. Cheers.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
