a/c refrigerant low
Happy Motoring...
I hesitate to offer this, but will anyway, locate the 'larger" of two dia AC lins connected to the compressor. This will be the low pressure or suction line. On this line (larger of the two) should be a schrader valve (like a bicycle tire) fitting. Forgive me is I make this sound so juvenile, as I don't mean too. Just want to insure one is making the right choice.
Happy Motoring...
Happy Motoring...
Received 6,312 Likes
Keep two thoughts in mind....
1. idle the engine
2. turn your AC system on high
If you have, (you should) what's called a "pencil thermometer", insert it in a central AC outlet. Then have it....good luck!
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
