A/C stale smell
You may want to check your ac condensate drain tubes. Accumulated/trapped water within the ac ducting/plenum may account for the smell. Start with looking for a small puddle of water under the car after a run. You want to see this. If no puddle, then you have a problem.
Also, look for a wet right side carpet near the console. That indicates an advanced problem. Good luck.
